So as I mentioned in an earlier post, I has having issues with my car alarm going off in the middle of the night for no reason. I would walk out and put the key in the ignition and start the car and it would go off.
I was told that the car has a primary and secondary alarm and then when the batteries on the secondary alarm go bad, the alarm randomly goes off. I've seen on numerous Saab forums across the web that it is located under the drivers side front tire wheel well and can be removed (I don't care if the back up alarm works). When I took the front tire off and peeled back the plastic in front of the tire, to my surprise I saw no alarm. It's simply not there. The only thing I could see was the wiper fluid reservoir and tubing. I even looked all around the front tire area there is no alarm there. Does anyone know if the 2007 9-5 has this alarm in another location?
It hasn't gone off recently, but fingers crossed....I'd like to avoid it from happening. Thanks.
