Hi first post here, I have a 2007 93 2.0t, over the years I've replaced all the parts in the front including outer tie rods, control arms, front shocks, I never touched the rear until a few weeks ago. I was always told the rear bolts were seized so I cut them out and replaced all the camber and toe bolts. All new control arm stays, and all new rear lower control arms i thought it was the rear that was throwing it off because i wasnt able to get it adjusted until yesterday. Just got an alignment yesterday and the rear is now in spec and car still pulls to the right.
The paperwork says the camber is out of spec on the right side but shows it being too negative. I know it's non adjustable but just ordered a set of camber bolts Everything I read on the internet says a car pulls to the side that is more positive. From the paperwork the right side is more negative so I'm confused. Will camber adjusting bolts added to the front of both sides being adjusted to spec and equalled out fix this problem? Also how do you fix the caster out on the left? Thanks!
