1 - 7 of 7 Posts
first check to see if you have solid or vented rotors, then head over to rockauto.com and order some. Aero is for vented and linear/arc are for solid. Just because you have an aero does not mean you have the aero(vented) rotors, so please check, so you don't end up like the guy a few threads above you. Vented rotors will have a gap between the front and back plates and solid is well solid...
he has an 07 aero, they all came with vented 292mm rears.
the ones in my rear are not oem ans they make a chattering noise, whatas a good brand that wont cause the noise? ty
anyone have a good place to get brakes for an 2007 9-3 aero
?? ty
Let me help you out since no one is the forum ever stays on topic...
Online:
TireRack.com
GenuineSaab.com
Saabusaparts.com
SummitRacing.com
Local:
PepBoys (EBC authorize dealer)
Bennett Auto
I've had stock rotors/pad (semi metalic) and centric/akebono (ceramic) and I prefer stock by a long shot. Apart from the dust it has a better bite and stops quicker.
Online:
TireRack.com
GenuineSaab.com
Saabusaparts.com
SummitRacing.com
Local:
Bennett Auto
thank you!
Fyi My arc has the 292mm vented rears. It's better to measure them before ordering...
1 - 7 of 7 Posts
