1 - 17 of 17 Posts
Hello, I'm having a bit of an issue with my Saab 9-3. Whenever I get on boost in fourth or fifth gear, my engine shudders a decent bit, feels like a misfire. I also got the P1312 code, which pointed to either the plugs or coils being bad. I had previously replaced one of the ignition coils when it failed a few months ago, and replaced another one today with one from Standard Motors, part number being UF526. I know that Intermotor ignition coils are considered to be good replacements, and I believe that Standard Motors owns Intermotor. I do not believe the issue is from the ignition coils, but rather the spark plugs. When I pulled the spark plugs out to properly gap and clean them, I noticed one of them has a hairline crack in it. Would the issue be caused by the cracked spark plug? I'm hoping it is. Also, what is a good way to test ignition coils, just to make sure the other two are not on their way out.
wrong coil
replace plugs too
Well shoot, I thought Intermotor ignition coils were good. Do Standard Motor coils really not work, despite owning Intermotor?
Never assume. If it doesn't have the stamping then likely not.
Darn. I'm going to replace the cracked spark plug and pray that it fixes the issue. If not I'm getting a refund from amazon and going to autozone, where I'll make sure the coil has the stamp on it.
For ease of reference.
So I replaced the spark plug, applied dielectric grease to the plugs and coils and cleared the codes. It seems to be running a good bit better now, code hasnt come on after about 20 miles wheres yesterday it came on after 2 miles. Now its able to be pushed through 1st gear to 4th without any stuttering, but on 5th gear it does jumble a bit. That may just be me lugging the engine a bit, and should downshift to accelerate. I'm planning on greasing the ignition wires with dielectric as well, as I have yet to do that.
I've never used dielectric grease on coils.
Discussion Starter #9
Yea just was a experiment. Currently the code came up again, so I guess its refund time.
Discussion Starter #11
So I returned the Amazon ignition coil, and got 3 new ones from advanced auto parts, the Intermotor E1026. However, two of them do not have the stamping on it. Did I screw myself again?
Discussion Starter #12
I also had to go to 3 different Advanced Auto Parts as each store only had one in stock.
yup. gotta be stamped. autozone duralast sometimes are stamped.
Discussion Starter #14
Yea I was able to return the two unstamped ones, and no more check engine light. Luckily I was able to get one good coil out of three stores. Now onto replacing the engine mounts, thanks for your help guys.
Discussion Starter #15
Any engine and transmission mount recommendations?
1 - 17 of 17 Posts
