EDIT -
To put it simply - take your time and don't rush headlong into cutting those hard fuel hoses on top of the fuel pump - especially on a 2006 9-5 because the pump won't come out the top hole - it's not a big huge deal to unmount the tank and drop the exhaust and unclip the parking brake lines. It just takes a little time but really it's pretty easy. Just be safe about it and use the right equipment / jack stands etc. on level ground if you're doing it as a DIY'er
I ordered my part from AMZ / Spectra Premium SP5121M Fuel Pump Assembly and will update this post after some time in the event the pump doesn't last but I have faith
Hi All,
Intermittent starting for a month - then she quit starting altogether - I was thinking it was either fuel related or electrical. After a few sleepless nights worrying about it ( novice here ) I saw a write up that said "just whack the tank" - which I knew I could confidently do! I went under the back seat and gently tapped the top of the fuel pump assembly with a rubber mallet and viola ! She started right up !! I drove her around the block and went inside feeling very accomplished and said "Honey I figured it out - come look!" We went outside and I turned the key - no juice again!
I'm fairly confident I need a new fuel pump - she's not making any noise at all when I turn the key - ( but she did rumble after the first whack with the mallet ) - so I am looking for the fuel pump ordering information -
I read the write ups from:
DIY - Saab 9-5 : Fuel Pump Replacement and
Al's Red Wagon - Fuel pump support needed...
plus others -
I'm a bit pensive about the clips and such ( sorry to hear about Josdek's bad luck ) but I'm going to take it real slow with a lot of lubricant and such -
Can anyone confirm the part number as a Bosch 69424 ?
I'd like to order it up front so I don't have the tank unsealed for a week under the back seat while the part is coming in the mail -
thanks in advance !
Hi All,
plus others -
thanks in advance !
