Hello group. Newbie here and pretty green when it comes to really working on cars. I have a 2006 9-3 2.0T combi.
Recently went into a temporary "limp home" mode and pulled 2 codes P1681 and P0223. From other threads, most everything is pointing to a bad TPS but others are saying it could be the ecu and that the TPS could be false fault.
I cleaned the throttle body and replaced a bad o-ring on a mass air flow sensor (the one before the throttle body). I reset the codes and so far (about 2 days) the check engine light has not come back on and it drives great. Not convinced I really did anything of real significance though (TB was actually pretty clean already).
Before I dropped $400 on a new throttle body assembly I wanted to test the specs on the TPS to make sure it was actually bad. I have a multimeter just don't know what pin combination to test or what it should read. Can anyone provide info how how to test the TPS. Any help would be appreciated.
