Hi guys- I've been scouring this board (and everywhere else) for information on my 2006 Saab 9-3 AC. The AC was blowing ice cold, went into a meeting and when I came out, it would not come on. The ACC unit comes on, but nothing. Here's what's been checked:
1. Maxi-fuse #35 & #36 (pulled, checked with meter, both good)
2. AC compressor Relay (still good)
3. Jumpered AC Relay location and compressor does click in
4. AC compressor fuse (pullled, ohmed, still good)
5. Thought my low speed cooling fan & fan controller was questionable, so I replaced Both cooling fans and fan controller. Did Not help and what a pain job.
6. cleaned contacts on air temp sensor and coolant temp sensor
7. Outside air temp is reading correctly
8. AC system has full refrigerant charge per my AC gauges
9. Performed the 4 power/ground tests on the connector for the cooling fan controller and everything functioned correctly.
So, I'm at a loss here. I don't have a Tech 2, and I'm 3.5 hours each way from a viable Saab dealer (or whatever you call them now). I'm in the middle of the Mojave desert, so not any help around me. From my reading, even if the cabin fan went out, the AC system would still come on and cool the evaporator. Thanks for your help.
