2005:
Linear = 2.5L 165HP H4 166 torque @ 4000 RPM
Aero = 2.0L 227HP H4 217 torque @ 4000 RPM
2006:
2.5i = 2.5L 173HP H4 166 torque @ 4000 RPM
Aero = 2.5L 230HP H4 235 torque @ 3600 RPM
So basically the 2006 Aero has more torque at a lower RPM, and im
guessing that it would be more reliable in the long run to pull almost the same HP out of a larger displacement engine
SaabScott said:
I stand corrected ... but I'm going to dig further.
I was told that the 2006 model just had the engine tweaked a little more ...
Yes, the 2006 just offers two different versions of the 2.5L, no "new" engines were introduced... Essentially the exact same changes subaru made to theirs
I dont believe the STI tune was ever introduces to the wagon models, however....
The 2006 Higher power 2.5L (saab) Has a compression ratio of 8.4:1, while the STI's same basic engine has a ratio of 8.2:1 , so im suspecting reaching
near STI levels would reqire little changes to the engine, and would mostly just require the ECU to be tuned, because the compression ratios are so similar.
