1 - 2 of 2 Posts
Help!,
Vehicle threw codes P0245, P0201 to P0204, indicating ECM failure. Started looking in to problem, then took off connectors, noticed corrosion on right (drivers side connector) at the front of the vehicle, one pin stuck in female connector, left, fourth from front. Also noticed others "loose". Can I get a replacement ECM and how would I get it programmed if I cannot use the existing one. Or does this mean I have to throw the vehicle away.;oops:
U should still be able to clone then existence ECU, this pin doesn't affect COM.
Use OBDLink and trionic software .
Ur problem will be to secure new engine harness, as the corrosion will transfer to the new ECU in no time .
1 - 2 of 2 Posts
