Both my front door speakers have stopped working in my 2004 93 Aero with premium sound system. I tried replacing one but was still not getting a signal. Any ideas?
have you lost your warning chimes aswell..
the door speakers are powered by amp1 under the front left seat
check connections & whether in & around the amp is wet...
I do have chimes coming through the dash speakers. Do the dash speakers also run off this amp? I did have a flood in the drivers side front, and rear so the amp is probably cooked, it is rusted on the bottom. I loosened the hold down screw but could not move the amp far enough to get a look at the connections. Looks like the seat has to come out to get at it. I probably need a new amp. Will try the junk yards. Do you know what other years or models I might be able to find an amp in? Thanks for the reply.
