21 - 30 of 30 Posts
They look that they were in place since 2010. I'd say that these caused your issues.
No oil etc. supposed to be there.
Remember that only original coil and NGK spark plug will work.
Are those DTCs after erase and re-read?
Discussion Starter · #22 ·
Yes, recently erased after new throttle body. Where is a good place to buy these new coils and plugs?
Discussion Starter · #23 ·
do you think the gaskets are ok or, just a problem with misfires causing this oily gas?
Do you think the evap system may play a role in this? Sure, im going to replace them to spec, im just looking ahead to try and predict if anything other than non oem coils and plugs could be playing a role here. 😀
Discussion Starter · #25 ·
you've got engine oil leaking into the plug chamber(should be bone dry) from failed rocker cover gasket..
ok, thats what I thought 😭😂 Ive replaced it before. Might hire it done, but I will probably take it off myself and see if I can get it on there correctly.
any tips are appreciated!
thanks for helping 😀
-Lucas
Discussion Starter · #26 ·
Fuel sender issues are common on these cars. Do a search.
What codes do you have?
ACC SEAT TEMPERATURE SENSOR B1927
ACC COMPARTMENT TEMPERATURE B0166
ACM DRIVER SEAT POSITION B0084
BCM OUTDOOR TEMPERATURE B0158
BCM UAM, SIGNAL ERRATIC B3812
BCM UAM, SIGNAL, OPEN CIRCUIT B3812
DDM MIRROR UP/DOWN POTENTIOMETER B1595
T8 CYLINDER 2 MISFIRE PO302
T8 FUEL LEVEL SENSOR CIRCUIT P0463
T8 ENGINE COOLANT SYTEM P0116
T8 CHARGE AIR BYPASS P0033
REC TRUNK LIGHT CIRCUIT B2570
REC BACK UP LIGHT LEFT B2545
STC 1ST BOW LOCKED B1300
REC FRONT WASHER RELAY B3873
REC SIDE MARKER LEFT FRONT B3871
REC SIDE MARKER RIGHT B3872
REC LOW BEAM LEFT B2575
REC LOW BEAM RIGHT B2699
REC HIGH BEAM LEFT B2580
REC HIGH BEAM RIGHT B2580
ACC B1927 seat heater censor failure, typically wire broken. Check wiring loom between ACC and seat(s), if they are OK, replace heater element.
ACC B0166 cabin temp sensor failure: Check wiring loom between ACC and sensor, if OK, replace sensor.
ACM B0084 seat position sensor failure, check wiring under seat.
BCM B0158 ambient sensor failure. Check wiring and if OK, replace sensor.
BCM B3812 cabin ultrasonic sensor failure, check wiring looms between BCM-REC-cabin light assy. If ok, replace sensor.
DDM B1595 driver door mirror motor failure. Check wiring between DDM and mirror, if ok, replace mirror motor.
T8 several failures, possible T8 failure, replace T8.
REC several failures. Replace bulbs.
STC B1300 1st bow lock failure. Check wiring, if OK, replace lock module.
Discussion Starter · #29 ·
awesome! Ty bro!! I have work to do, thanks for your help!! 😀
well, it looks like I have some more work to do
I want to focus on removing the fuses and relays to the non-essential components that are throwing error codes.
It looks like I have some serious electrical issues to work out after I get the engine working properly. My main focus right now is the fuel system. Im getting rough idle and apparently misfires. Ive changed the spark plugs and wires. My fuel system is having problems. I need to fix the gas gauge not working and as you can see above, it doesn’t even recognizethe evap system. Any tips on what to try to get my fuel gauge working as well as test the evap system? It has a new fuel pump and that did not fix the problem. What components should I check other than the fuel pump which is brand new?
I posted a video which shows how the car is idling. Ive just replaced thethrottle body and the car has its power back, but itsrunning very poorly and will sometimes still go into limp mode. Any suggestions on getting this car running more smoothly so I can drive it while working out the non-essential components?
thanks
-Lucas
You have a problem with either a Coil or a Spark plug on Cilinder #2
Cooling System is not working properly...check thermostat and replace and temp sensor too.
Charge Air Valve on top of Turbo is bad.
Replace that one.
Check parts at eeuroparts.com
hope this helps.
Cheers!
21 - 30 of 30 Posts
