1 - 20 of 30 Posts
Communication Device Gadget Audio equipment Mobile device Display device
Gadget Audio equipment Peripheral Electronic instrument Font
Computer Gadget Personal computer Output device Font
well, it looks like I have some more work to do
I want to focus on removing the fuses and relays to the non-essential components that are throwing error codes.
It looks like I have some serious electrical issues to work out after I get the engine working properly. My main focus right now is the fuel system. Im getting rough idle and apparently misfires. Ive changed the spark plugs and wires. My fuel system is having problems. I need to fix the gas gauge not working and as you can see above, it doesn’t even recognizethe evap system. Any tips on what to try to get my fuel gauge working as well as test the evap system? It has a new fuel pump and that did not fix the problem. What components should I check other than the fuel pump which is brand new?
I posted a video which shows how the car is idling. Ive just replaced thethrottle body and the car has its power back, but itsrunning very poorly and will sometimes still go into limp mode. Any suggestions on getting this car running more smoothly so I can drive it while working out the non-essential components?
thanks
-Lucas
What spark plugs and coils you use?
Your pic shows only 50C engine temp. That is not enough for O2, cat etc.
I'm not sure what plugs and coils I used, can you recommend new plugs? I figured I would probably have to take them out anyway and expect them. What should the engine temp be? Does this mean the plugs are not firing properly? or??
What plugs should I try? I guess I can try new plugs if you think it will help, and if it does fix the misfire, then I will be happy! If it doesn't, I can try the wires... and then whatever else!!
Thank you for your help!!
thanks
-Lucas
Well, it shows the codes in the video... I have so many codes that as I fix things, more pop up and develop... I have new codes since the last time I wrote them down. I will make a text list of the codes to post in here. Thanks for your help, I will get the updated codes typed out and come back soon!! ty bro
Only original coils will work, no exceptions.
Use NGK PFR6T-10G spark plugs.
Normal engine temp is around 85-95C.
Awesome!! Thanks bro! I am going to buy these! Later tonight I am going to look at the video and write down all the error codes. My main focus is to get the engine running smoothly with the gas gauge working. I believe is has the factory could on it, and if these plugs don't fix the misfire, I think maybe I should replace the coils first or the wires first?
I am worried that maybe some components were damaged. I had water leak in through the cabin filter and there was a pretty good char on the blower connector. I replaced the blower and used the same board.. I inspected the board and there was no damage. It looks like it is now working after changing. I'm also having a really hard time with the lights, I think maybe there is a failed component there, and maybe a wiring fault. I'm thinking maybe I should pull all the fuses to these systems until I have the engine running correctly???
What do you think? Change the plugs, then wires, then coils? I'm buying these plugs then what is the next step? I suppose I should pull the plugs out first and inspect them to see if they are already the correct plug?
ok, thanks a lot, I am going to come back later and post all my error codes!!
Thanks a bunch!!
OK bud, do you think I need new coils? If so, I will buy new coils... Should I wait until I make sure I have the correct plugs?
Discussion Starter · #10 ·
Fuel sender issues are common on these cars. Do a search.
What codes do you have?
I will come back later!! I think there is an evaporations code and some other fuel system related.. I did replace a purge valve and I think maybe it was the culprit, but it didn't fix the problem. I'm not sure where to start with fuel system diagnosis but I think it may be purge valve related, and definitely an evap problem... How do I diagnose the fuel system?
Thanks so much
-Lucas
Discussion Starter · #11 ·
ACC SEAT TEMPERATURE SENSOR B1927
ACC COMPARTMENT TEMPERATURE B0166
ACM DRIVER SEAT POSITION B0084
BCM OUTDOOR TEMPERATURE B0158
BCM UAM, SIGNAL ERRATIC B3812
BCM UAM, SIGNAL, OPEN CIRCUIT B3812
DDM MIRROR UP/DOWN POTENTIOMETER B1595
T8 CYLINDER 2 MISFIRE PO302
T8 FUEL LEVEL SENSOR CIRCUIT P0463
T8 ENGINE COOLANT SYTEM P0116
T8 CHARGE AIR BYPASS P0033
REC TRUNK LIGHT CIRCUIT B2570
REC BACK UP LIGHT LEFT B2545
STC 1ST BOW LOCKED B1300
REC FRONT WASHER RELAY B3873
REC SIDE MARKER LEFT FRONT B3871
REC SIDE MARKER RIGHT B3872
REC LOW BEAM LEFT B2575
REC LOW BEAM RIGHT B2699
REC HIGH BEAM LEFT B2580
REC HIGH BEAM RIGHT B2580
I had literally just started the engine seconds before I started the video. I will let it run and check this. Here are my engine codes, looks like cylinder 2 misfire.
Discussion Starter · #14 ·
Well, heres a problem. Oil in the plug boots and all over plugs.
The plugs in here are NGK BKR6EEIX
I replaced the gasket and maybe I need to replace it again. I don’t think there should be oil in there like that!! 😂
Photograph Light Black Wood Automotive tire
Automotive tire Bumper Wood Automotive exterior Asphalt
Photograph White Light Black Grass
Automotive tire Insect Auto part Soil Metal
Discussion Starter · #15 ·
Discussion Starter · #16 ·
Discussion Starter · #17 ·
Discussion Starter · #18 ·
Thanks so much
-Lucas
You should replace spark plugs and coils ASAP. They look horrible.
Have you erased all DTCs before read?
Discussion Starter · #20 ·
yes
I will replace the plugs and coils, but my question to you is… why are they that oily? Is that normal? Should there be a little oil in there like that? It looks like oil and gas? I did replace the valve gasket? It this normal for it having missfires and for it running poorly? Is it normal for this liquid to be there?
thanks
-Lucas
1 - 20 of 30 Posts
