1 - 14 of 14 Posts
2004 Saab 93 Arc Convertible
First off, Thank You
For future reference, how do I find the exact engine that this car has?
Ive recently purchased a tech 2 clone and I have it communicating with the vehicle.
Symptoms:
  • very low power, seems to be in limp mode
  • erratic fuel pressure, needle bounces around violently near 35-40psi
  • fuel gauge jumps around, then returns to zero
  • car idles ruff
  • barely drives
What I’ve tried:
  • New fuel pump, exact same issues
  • New fuel pressure regulator
  • New purge valve
I’m looking for the exact steps to hooking up the Tech 2 and diagnosing the fuel system.
These are the error codes I have. If you see any that may be effecting the fuel system, please recommend steps to diagnose.
Thank You for helping
281296
281297
281298
281299
b3057 is module not added with tech2..address the T8 ones..
Are they all current or did you clear them all and see which ones pop back up..
Are they all current or did you clear them all and see which ones pop back up.. Ok, I will look into the t8’s
how would I address the module not added?
what does that mean? Modules not added? I think I may have messed up a module trying to get it to copy a key.
Might want to try readding the cim as that is what the fobs are programmed too..
you can't copy fobs you can only remove/add them...used fobs can't be used..
right, add is what I mean. I bought a fob for it and it didn’t work, so I have a own fob I’m going to try…
Im sorry if I am new, but what does re-read the CIM mean?
I am sorry, I just don’t know the lingo
OP could have 315MHz fobs (P/N 12783780).
What I see is you have throttle body failure.
What do you recommend? I believe I’m going to take the fuel injectors out and test them first thing. I’m wondering if I can make a video of my tech 2 readings while the system is running on the vehicle to provide more feedback on the issue. Where do I need to look in the tech 2 to check for normal values and diagnose exactly where the problem is?
How do I test the throttle body? Can I clean it?
ty brother 👍🏼
there is nothing wrong with the injectors,like going to the ER with a broken leg and them putting a cast on your arm then saying you can go....
315MHz not in the US..
Discussion Starter · #11 ·
Does anyone have an idea about the fuel filter on the 2004 arc turbo? I’ve heard these models don’t have fuel filters. Any idea why these might not have a fuel filter? If they do have a fuel fifer, anyone know where it is?
no external filter on the US models,only screen filter on pump assemly..
you need to sort out all those code/s before anything else...
1 - 14 of 14 Posts
