Thanks to the help from this community I was able to successfully install a 6-disc in-dash changer to my original 2004 9-3 Arc convertible system that came with a single disc changer. All mechanical and visual displays (on radio, SID, etc.) work as designed, however, audio does not. You can see the disc changer playing tracks and see when it change to the next track. I can switch between discs, eject / install as designed and use the random function. Just no audio.
I reinstalled the single disc changer (doesn't eject & disc stuck in that plays ... common problem) and audio works.
Looking for a solution to the audio issue. I saw a UKSaab site dialogue suggesting it may be a wiring harness change; they stated swapping the red and yellow wire locations enable 6-disc changer audio to work. Didn't see a schematic on wiring so unsure which wires and if this is the actual solution.
Does anyone out there have the solution?
