Hello,
I just wanted to know if anyone knew of a schematic for the alarm system of this car? I have the manual but it does not have any information about disarming the alarm. I just want to cut the wire or disconnect it because it keeps going off and am tired of having to charge the battery over and over. Does anyone know how to disable the alarm?
2008 Saab 9-3 Aero FWD 6MT
If the alarm keeps going off, you should look into a malfunctioning door lock actuator/door ajar switch. A Tech2 will give you more details and possibly a DTC for a bad part somewhere. If you don't care about it too much, check WIS for more detailed diagrams, you can probably find out which wire leads to the alarm and cut it, although I'm not sure I'd recommend it.
Thank you. I will check WIS for wiring, but rain did get inside because I forfot to close windows so most likely switch did get wet
