Car will not start reliably.
Symptoms
1. Turn the Key to start and I can hear a single click
2. lights turn off when "starting"
3. engine does not turn over.
4. wait 5-20 min and the car eventually starts up.
5. I have tried jumping the car without success.
6. while running I am seeing ~14volts
7. while not running 12.6V
8. won't start when hot
9. getting worse at starting when cold.
When the car does start it starts right up without hesitation.
I have tried using a modified paper clip method. however, i could not find a picture showing the process and i am not sure if i did it correctly. the problem is still occurring. Can i rule out the neutral safety switch?
Jumper connected to White Wire
Jumper connected to Black Wire
Neutral Safety Switch harness
The following threads is about a different year so i could not follow the procedure.
http://www.saabcentral.com/forums/showthread.php?t=100345
and
http://www.saabcentral.com/forums/showthread.php?t=109861
