1 - 11 of 11 Posts
I have a 2003 93 Arc and both my low beam headlights are out... what are some replacement bulbs that are on the cheap side? (if any) Thanks!
How can I tell? Is there a sticker under the hood that says? I bought the car used, all I'm sure of is that it's a 2003 93 arc.
When you start your car, did they headlights dip down then com up and self level? If so you are Xenion. If they did not, you are Halogen.
Those Bulbs are awfully cheap and the Color Temp is a little on the Low side will look like tungsten/Incandesant, I think stock is 4300 Kelvin.
Xenon-D2s Halogen-H7
http://www.mrandmrs-g.net/LightingGuide/index.htm
JonV thanks for your help... unfortunately I honestly have no idea. Will the dealership be able to tell me by looking up my VIN?
Yes, or use the directions in the tech help link i posted to pull one out and see for yourself.
So I called the dealership and they told me that if the bulbs were xenon, there would be a yellow warning sticker for "high voltage" under the hood near the headlights... I looked and there was no warning sticker so I'm assuming halogen bulbs.
What are some decent cheap replacement halogen bulbs? Thanks!
1 - 11 of 11 Posts
