21 - 25 of 25 Posts
I decided to do a quick google search for you on this flashing light issue. I don't know if the DICE unit has anything to do with the A/C issue your having, but sounds like it is definitely the first thing you should replace for the lighting issue. Check this out:
Body Control Module (this link is from the above post)
Make sure you can return the used one that you find, obviously. In case it doesn't solve the problem.
Discussion Starter #22
Thanks for that link! I would be thrilled if I could get the programming done for around $30.
Update:
Ground points are verified good.
I have a used DICE that I pulled for the same year Saab at a local lkq, but it was an Aero sedan not an Arc wagon. Essentially the same options and the car was in fantastic condition. Perfect leather front vented seats!
It's a challenge to find it under the dash and get it out. It's really hidden on top of the large white cube (junction box).
I haven't tried it yet, but I've found more issues that also point to the DICE. The turn signals are intermittent.
A few more questions
1) will it lock my radio or will it work again with my original DICE?
2) If I go back for the radio form the same car, can I possibly skip the marrying of the DICE?
3) Any recommendations on a SAAB place in Austin, TX to do the programming?
Discussion Starter #25
I haven't seen any rodent mice evidence, but there is a family of sparrows or maybe titmouse (a type of bird) that continually starts a nest at the base of the windshield under the hood.
21 - 25 of 25 Posts
