21 - 31 of 31 Posts
Discussion Starter #21
I dont see anything for SCL that I can do a command to. When I pull bus activities I do not see scl anywhere, I am new to the tech2 but I've looked i look again
Can you turn the steering wheel with the key out of the ignition?
It sounds like SCL or wiring from it is bad, then.
Tech 2 pic means system is blocking on SCL unlocked status. It would say OK otherwise.
B3948 is informational only; there is an SCL fault code stored. I have attached instructions for B3948 code from Service Bulletin in WIS for your MY to retrieve the actual code.
274911
Can't the SCL be disabled with the Tech II since you have one?
21 - 31 of 31 Posts
