Hey guys, I'm new to this forum. I purchased a 2003 9-3 Vector from Saab of Milford in Connecticut in September 2006. It has about 44K in miles and is covered by the Saab CPO warranty until July 2009. The only major trouble I've had is:
Email brake repalced - Jan 07
Passenger window regulator replaced - July 07
Transmission replaced - Aug 07
Now, one thing that has always bothered me from time to time is that occassionally, the car violently shakes when the engine starts up. I'm not really tech savy, so I'm not sure what terminoligy to use to even describe my problem. However, I've discovered that when the key is turned to the "on" position, you can hear something "wind up/cycle" in the front part of the car on the passenger side. Most of the time the "wind up/cycling" sounds smooth, and ever thing is cool. However, sometimes the "wind up" process sounds different and whatever it is that is making that sound sounds like it's having trouble doing whatever it's doing. When the "wind up/cycling" process sounds different is when the car will shake upon starting the engine. Once the engine is started everything seems ok, but this really bothers me. The car is, like I said before, covered under warranty, but I would love to be able to tell them EXACTLY what I think is wrong with the car instead of using my horrible descriptions to lead them on a wild goose chase.
Another problem is that I hear a wierd sound coming from right below the windshield. It is another "cycling" kind of sound, that is directly related to the thermistat I believe. I say this because if it's set at 70, and I raise it to 74, you will hear this thing "cycle" for 2-5 seconds. Change the temperature again, and you get the same results. It also makes these sounds randomly, even if you don't change the temperature. Any advice as to what the hell is causing that?
Any help from you guys would be much appreciated. Again, it's a 2003 9-3 Vector. If you guys need to ask me for any more details, please feel more than welcomed and I will do the best I can.
Thanks
Thanks
