1 - 2 of 2 Posts
after i replaced my front brake pads and pumped the brakes to get pressure back in the system while the car was started the pedal would depress to the floor. while the car is off the brakes are fine... is this normal? the braking power seems normal
your pedal continuing to move AFTER bleeding the lines is normal. The braking on the 93's have a pump activated by the pedal movement, not direct hydraulic pressure. If the braking feels the same and your stopping ability hasn't changed, you're fine.
1 - 2 of 2 Posts
