The "running lights" come on when the car is started. This includes the low beam lights and all of the tail lights.
When the headlight switch is turned "On" nothing changes, all the lights remain exactly the same. However, you can not turn on the high beams or fog lights until the light switch is turned to the "On" position so this tells me that something is taking place when the switch is turned "On".
Problem - The low beam lights are sooooo dim, you can't see the road 5 feet in front of the car. Turning on the fog lights helps...a little but not enough to drive safely. The only way to see adequately is by turning on the high beams and of course this isn't practical.
So far, I've replaced the existing H-7 low beam bulbs with the brighter version of the same bulb (H-7). I replaced the White relay in the fuse box under the hood and I even replaced the blown marker bulbs next to the high beam bulbs just for good measure.
All of the other lights on the vehicle work...interior, side, blinkers, reverse, license plate bulbs, vanity mirror bulbs, etc...and I haven't detected any other problems with the overall electrical system.
Is this model suppose to have "running lights" that come on and stay on while the vehicle is running?
Also, I'm suspicious about there being no visible change in the lighting when the headlight switch is turned on. ( I removed the switch from the dash and visually inspected it for problems but didn't see any).
*These are not the Xenon head lights*
Any ideas, tips, suggestions are appreciated. I'm at my wits end with this issue.
