I see 2 issues here:
1. The wipers would have to go (would scratch plastic) also the shape is wrong. so as someone else noted you need a 02+ bumper and there are some things that need changed to get that to fit.
2. The leveling system. This system is actually integral to the lamp. It does not move the headlight itself but moves the inside carriage. If there is no signal from the sensors then it will most likely default to the low position which will not get you much light where you need it. You could likely de-power it but I am not sure if there is any lamp power cutout relay or something (doubt that last).
3. Ok, I lied and said 2 but there are more...The power plug is different for the xenon. The plug provides power to: Ballast for HID bulb, halogen (inside H7) bulb - used for flashing brights when DRL fuse removed, city light, High beam solenoid, Leveling motor. These are not just things you can tap into a 12v line from the battery as they are controlled by relays and sensors.
