Hi--
I recently purchased a two door Viggen. It came with ASA spoke rims. I would like to explore other rim options. Can anyone tell me if mid-2000 95 rims will fit without rubbing? I am particularly interested in the aero twins found on 2005 95.
I understand that the offset of the stock Viggen rim is 43 mm. It is also my understanding the the offset of the aero twins is 47 mm. Does anyone know if a 4 mm differnce will cause the tire to rub? I'd also appreciate seeing a photo of an early 2000 93 or Viggen fitted with aero twins if anyone has one.
Thanks,
--Papermaker
Assuming the 9-5 rims are 17" and you run the right size tires they will fit. There is way more than enough clearance to play around with offset on nearly every mass-market vehicle.
Tire sizes
Thanks for the reply. The rims come with the following tires:
Two are Pilot Sport 2s 225/45 Z8 17" and two Pilot Sports 225/45 z12 17" tires.
Papermaker
