My 2002 Saab 95 Automatic when switching from park to drive after oil change it got a little better but still happens i took it to my local Saab dealer they said it might need a new Trans Unit (They werent even really sure and dont wanna invest and find out that isnt it )? Can anyone help The jerking only happens 1s the car is warm so after 30 mins at the begging it works perfect ,I just bought the car and didnt notice it till after i drove it to work ? Car only has 110,00 miles
This box, an Aisin Warner, is notorious for this problem of hard shifts. The ultimate fix is a new or recon valve body, it does not need a new box.
Any competent trannie specialist knows the problem, it affects not just Saabs but also Volvos and others.
At this stage with your car make sure it has had a full trannie fluid flush, not just a simple change. Then check to see if a software update for the box has been done as that may help the shifting.
If that doesn't fix it a trannie expert can fix new solenoids into the valve body or fit a recon body. Its a very simple procedure that doesn't even need removal of the box. Here in the UK a local Saab specialist will fit a fully recon'ed body for around £450.
