I am new here. Great forum.
2002 SAAB 9-3 2.0 L B205R turbo w PCV upgrade done @ 50k
mileage 148k and 3k on ‘amateur’ rebuild :roll: bent valve repair and no sludge
I need help with the following conditions.
bluish white billows of smoke from exhaust, heavier on deceleration
bluish white smoke from oil filler tube with dipstick out
with dipstick out, there is also a light oil splatter coming out of filler tube
Lots of oil loss- back of the engine passenger side
Lots & lots ….. the hose from the sump to oil trap is covered
Oil is everywhere at that location due to driving conditions
When I clean it up and put it on ramps running at idle, no sign of leaking
Observations:
No leaks in area of Oil Pressure sensor, above starter
No leaks around Head gasket or cam cover gasket
No leaks around the fitting of the sump
No leaks in area of Oil Pump and Crank bearings
No coolant loss at all
All three PCV check valves were tested via blowing from both directions
Engine runs very good, very strong, lots of pick up and power
Check Engine Light and oil pressure light on dash are unlit
Oil does not seem to be contaminated, it is clean and clear
I would be pleased for several responses like this …
What to look for ….
1. ….. first mostly likely
2. ….. second possibility
3. ….. third it could be this
Any detail is welcome. I enjoy the read, but sometimes get lost in the middle of a paragraph.
That’s on me, not anyone else. Thanks in advance.
Observations:
What to look for ….
