A week ago I bought a 2002 SE convertible auto with 170k miles and have been going through it to see what needs fixing. A couple things that need to be fixed is the "soft top failure" on the SID and wobbly steering when driving.
For the top, I checked the reservoir and it was low so I added some lucas stop-leak up to the max line. With the key in the on position I then tried to open the top via the switch several times, but still didn't work. I gave up for the day as it was getting dark.
Anyways, I decided to go on a drive to see if the steering wobble went away after swapping the wheels front and rear wheels and it did! Was feeling great about the car as I thought it was a bad axle/cv joint from the grease I saw in that area. I drove around for about 15 minutes and pulled into my drive way. With the car still running and in park I decided to try the soft top again. As soon as I hit the "roof" switch the car just shut off. Not sure if it has anything to do with it, but I may have nudged the key in the ignition as I reached for the switch. Or is it just a coincidence that something like the fuel pump failed?
Problem: I tried to start the car again multiple times, but it just cranks. Tried it about 30 minutes later and still the same. Will try again tomorrow. Any ideas?
Other Info
-Battery: tested at 12.5v with the car off
-CEL: P0300 has been pending since I've had it, but car always started
-CPS: the tach needle moves when its cranking so I'm assuming the crank position sensor is good?
-DI Cassette: came with a Huco brand part #134063 and doesn't have the SEM sticker
-Fuel pump: possibility?
-SID: messages show "Service Theft Alarm" and "Time for Service"
-Spark plugs: replaced yesterday with copper NGK 6779 (BCPR6ES-11) gapped to spec
Other Info
