My SID display suddenly became very dim even though it seems to be working fine. At the same time this happened the park assist system stopped working but not getting any error code via the SID that I can see. Any ideas on the possible issues/solutions to fix?
Bulbs?
you can try swapping them around from the SID or ACC to see if the bulbs are bad. The easiest and cheapest way to replace them is to get replacement bulbs from radio shack and install them (and the little green rubber) yourself. The bulbs from Saab are outrageous.
Check the reversing lights, if they don't work then check the fuse. If the fuse blows again check the wiring to the boot (trunk) lid.
