Is there a receipt for a replacement turbo in there somewhere? The GT17 low-pressure turbo on that engine is not very robust and the bearings will fail. Pull the short rubber pipe off the throttle body and check for oil in it. If there's more than a little misting of oil inside the pipe then you know the turbo needs fixin'.
The "turbo" gauge is run by the ECU and is more of an engine load indicator than a vac/boost gauge. If you don't have the transmission in "Sport" mode then it's rare to get that gauge more than half way into the orange band since the ECU and TCU are running the "economy" program.
If the engine is high-mileage then the low oil pressure usually means the oil pump and/or bearings are worn. Moving up the oil weight scale might help you; I run 15W-40 in my son's V6 with 180k miles. There were no real sludge issues with the V6.
