At long last I am finally going to ask for help. I bought my Viggen last fall, and I love the car to death but it has its share of problems. It has a stage 3 JZW tune, good for about 350 horse, idk though I haven’t dyno tested it and I bought it with the tune on it. JZW has apparently fell off the face of the earth and I think I’m having a problem with the tune. I don’t even know where to begin... so it recently has been acting super weird. I press the gas, and it starts slow. I’m thinking in my head that it usually has more power, then all of the sudden it lurches forward at what what its supposed to be doing. I keep the pedal down the same amount and it will oscillate between boost, cut, boost, cut etc. I recently got rid of the cold air intake I had put on it and that worked for like a week but now its doing it the same if not progressively getting worse. I notice also that when it is ‘in’ and I let off the gas it crackles and pops (really cool with the 3” turboback), but when its not at full power it won’t crackle, just sort of hums. Also, I notice that when I push the clutch in sometimes the revs increase a little, then hang there for a second before going down. This, as well as first being sort of hard to get into as well as my shifts seem to be getting less smooth, led me to believe that the clutch was on its way out, so I took it to a friend of mine and he said the clutch seemed tight. Took it to my mechanic and he said the same thing. I thought it may be a boost leak but a smoke test came up with nothing. So that’s my biggest problem. Second on the list is a list of parts I need but can’t find anywhere, hoping some of you guys might have some lying around. First one is the gasket for the MAFS, as well as the screws that bolt the plate into the air filter box thing. Another part I need is a little tiny clip that holds the diverter valve in place, see pic. I have a makeshift one in place right now. Also need to find the intake plastic piece that goes back from the diverter valve to the throttle, pic as well. At full boost the diverter valve pops out of it and I can’t seem to make it stay even with hose clamps and zipties like crazy. I’m probably missing some things but I’m sure they will come out when you guys ask me questions.
1.7 MB
1.6 MB
1.9 MB
