I'm in the middle of replacing rotors and calipers. Because I would not be immediately replacing the old calipers with new ones (it's taking some time to get all of the old parts off and I'm painting the new calipers), the brake lines were left unattached. Some fluid drained out but seemed to stop with reservoir low but not empty. The next morning I saw that the reservoir had completely drained. When it comes time to bleed the system, I'm assuming I will have to do more than bleed the system at the calipers. Oddly, there is no procedure described in my Haynes manual for bleeding the master. I've heard before bleeding the calipers that I should do a manual bleed of the two green lines on the master, starting with the connector closest to the booster.
I will be bleeding the line with a vacuum kit. Can someone confirm that the above procedure is correct and the master bleed is necessary even with a vacuum bleed?
Thanks,
Mike
Thanks,
Mike
