1 - 13 of 13 Posts
FS: 2000 Saab 9-3 SE High Output Turbo $2500
This Car Is my baby, but due to a few more vehicles I own She has to leave home!, She daily drive about 2 miles and spends most of the time in the garage, Please serious offers only, If you want a Unique NICE daily drivable car this is for you!! And Reliable all the maintenance has been done and then some !! it is no harder or expensive to fix then you average car, don't let people lie to you this has been the easiest vehicle to work on I have ever owned ! No
Contact info
E-mail: [email protected]
Phone: 630-913-2820
Text: 630-913-2820
Model: Saab 9-3 (9400)
Model Year: 2000
Body type: 5-door (5D)
Engine: B205R 4-inline, High Output Turbo, PETROL, TURBO (B205 R) T7 ECU
Gearbox: 4-speed automatic
Plant: Trollhattan, Sweden, line B (900 / 9-3)
Market: Model series III, Driver and passenger airbags
Serial number: 015915
WALK AROUND VIDEO
http://youtu.be/bpktHcyHYtQ
Ebay add
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150896948195
Two Owner car
Handling
*Custom R1 Made Cryo & Heat treated Crossed Drilled Rotors F&R
*Hawk Brake pads
*Viggen Rear Shocks
Looks & Interior
*Boost gauge
*Custom 60Watt CANBUS HID with 75w bulbs (5800K) For Low beams
*35Watt ballast 55w Yellow Fog light's (deeper longer lasting yellow)
*Window Tint (20%)
*Grill Painted
*Painted wheels
*Carbon Fiber wrapped hood
*Carbon Fiber Eyelids
Sounds
*RockFord Fosgate Power Series Component system 6.5’s
*RockFord Fosgate Power Series 4’’ Midranges
*RockFord Fosgate Power Series 6x9’s
Performance
*Custom Made Turbo back Exhaust 2-3/4 with a 32'' resonator
*Magnaflow Muffler PART#: 14803
*NGK Spark Plugs
*Custom Upper Hard Pipe and Greddy blow Off valve
*Hand Ported Throttle body.
*Custom Revision Of the PVC system with catch can
*Genuine saab open air intake
Maintenance done with in the last year, Most Of was done right after I bought the car
*New Alternator
*New Fuel Filter
*New NGK Spark Plugs
*Windshield Wipers
*Oil changes (Only used Pennzoil Platinum Euro Spec 5w40 )
*Brakes
*Valve cover gasket
*Replaced all hoses
*New Front Brake Lines
*Intake Manifold Cleaning
*Pistons DE-Carbonized Cleaned.
*FMIC Cleaned
*Turbo Cleaned
*Tires rotated
*Painted engine bay
I'VE ONLY USED 93 NOT 92 or 91 OCTANE From BP, Shell, Citigo, & Mobil (Mobil Gives the best gas mileage)
Compression Tested as well
DRY 175psi 170psi 175psi 170psi
WET 180psi 180psi 180psi 175psi
The Bad
Will need New Battery by winter*
Tires need to be balanced, after I painted I never put the wheel weights back on,, I work weird hours, I find time I will have this done.
The BOV needs a Stiffer spring Not an issues unless you plan of beating on the car a lot.
Contact info
Phone: 630-913-2820
Text: 630-913-2820
It's the same as a Bypass valve when you recirculate it into the intake track, It works just fine and with the Open air intake you do actually hear it aswell.
Just wondering why you didn't list the replacement engine as one of the maintenance items. Also, can you prove to a buyer that the engine only has 30k miles on it?
Discussion Starter · #11 ·
You read that totally wrong The engine was replaced @ 30-33k miles... not the other way around. This was done buy the dealer if you call saab and give them the vin this can be showed to you.
congrats!
1 - 13 of 13 Posts
