hey all
2000 9-5 aero with some trouble...
issue: tsc and tranny lights are on and if I try to accelerate above 3000 rpm it shudders and won't go any faster. lights dim a bit when I push the gas pedal.
any recommendations???
You need to take it to the dealer and have the codes read. I take it this is an Automatic.
Many times the Automatic can be saved with simple repairs (the valve body troubles for example); however, it must be caught early.
How does the ATF fluid look? How is the fluid level?-does the fluid look burnt? Does the fluid smell like nothing much or like a burning clutch?
Were there any symptoms before this started? Was this a sudden problem, did it happen after an unusual form of driving?
Sorry to hear about your troubles, I know how it can feel.
not the tranny
well, just went back and can now drive her to redline :)
however, both lights are still on. weird.
could it be a failure of the warning lights on the dash?
