1 - 8 of 8 Posts
I have a 2000 9-5 and have a replacement climate control SID panel/control. Does it just pry out or is there another proper way to remove this? Your help will be appreciated!
Also, is there anyone who has a problem with the climate control working good ont he driver ss ide and either full hot or cold on the passenger side? I have heard about blend door shafts, but mine seems OK. I got a code meaning pass side blend door fault, but it appears to operate properly.
MANY thanks for your help here!:D
Same as the SID, it is pryed (levered) out.
How can you say that you got an eror that the air blows all hot or cold on one side yet it "seems to be working properly"?
climate control
I am sorry, I should have explained a little better. When I said "all seemed to be working properly" I meant the blend door shafts and levers are all intact, not broken. There is HOT air coming from the passenger side unless I have the climate control on that side set to "LO", at that point I will get cold air. Driver's side will abide by the setting on the control panel. Also, I guess teh rear is ponied off of teh pass side, because it is either hot or cold no in between.;oops:
recalibrating
I just installed a new display as the old one had a few pixels out and recalibrated it. I am getting a fault code 11 showing. I know an 8 is the DREADED code, but what about an 11? Do I really want to know?:evil:
1 - 8 of 8 Posts
