Figured I'd just do a quick update and share what my dad and I have been up to lately. Dad did the motor rebuild, I did the grunge work and helped out. Dads had a powersports shop for 20+ years and rebuilds motors constantly, all oil/lubricants were Redline Synthetics. Our favorite.
So back in August I was headed to Rutland VT and I'm blasting away in the interstate, sure enough the oil light came on and queued disaster. After a tow back home and a little check over I realized I had to rebuild this beut, 210k miles and in excellent condition.
So I've just ordered and received my parts,I'll post pictures of what I got below. While I was waiting for my parts I tinkered in little stuff, cleaning the head, manifolds etc.
Once we tore the motor down and inspected it we found the #1 & #4 Pistons scuffed, the journals on the crank were all good, and the oil had pushed out the main seal, maybe due to a PCV failure, I doubt it though. Oil pan was good, no sludge no shavings either.
Dec 5th, we put in the main bearings (glyco) in and replaced the oil pump assembly. The main caps were taken off and and we tapped each half of the bearing out then rolled in the new ones, assuring the grooves aligned and were lubed. Did this for all 5 journals in an hours time or so. We retourqed the caps and were done. The oil pump was straight forward, pull the wheel off, take the pulley off, replace the gears, and housing which came with a new seal. Then reassemble. We also put the new Pistons in the rods.
