1 - 11 of 11 Posts
i have two holset HX35G for sale. some shaft play, but nothing major or in need of repair. Both came off of a cummins 5.9L LPG engine. externally wastgated, unknown milage as the motors wwwre without the trucks. these turbos are a little different than most HX35s as they are oil and coolant cooled, has a larger 14^cm exhaust housing, but a little bit smaller inducer size on the impeller at about 50mm as opposed to most 54mm. but its a 7 blade which is the more desired impeller. should flow around 50-55lbs/min which should support 450-500hp.
price is $200 OBO eaxh
530-321-9905
Chico, Ca
Callen
1 - 11 of 11 Posts
