hnnng, cant resist it..:
what i (hopefully correctly) remember from studying is:
high octane fuel doesnt take longer to burn, it delays ignition.
modern engines, especially turbocharged ones, have high compression ratio, high mean pressures and also high maximum pressures. this is why fuel has to be used which has a higher ignition delay.
if the fuel were to ignite easily, you would have to delay the injection a lot in order to limit max pressure to allowable limits.
if this does not happen, knocking occurs, because the fuel ignites to early and ignition pressure rises very steeply whichresults in very high pressures.
because of this, the injection must be delayed when a lower octane fuel is used, which in turn results in a pressure curve which is more flat.
in general: early injection=high pressures, good fuel economy, late injection=low pressure, less fuel economy.
so if you use fuels which the engine is not designed for, the knocking sensor will delay injection which will result in less fuel economy. with the proper fuel, this does not happen, so not only do you get better fuel efficiency, but also more power (area under pressure curve greater(generally speaking)).
uhm, end of lesson;oops:
basically i just wanted to contribute that it really doesnt make sense to use any other fuel than the one that is recommended, but things got out of had while writing:cheesy:
