1 - 2 of 2 Posts
Hello. I was wondering if anyone had any ideas/suggestions regarding my current situation. I have a 1999 SAAB 9-3. After having my SAAB repaired and washed about a month ago, the next day I had the SID give me a "Front Light Failure" message and noticed that both the driver's side low beam headlight was out AND the turn signals no longer work. I tried to troubleshoot a little: 1) checked all of the fuses and none were out, 2) replaced the driver's side light bulb; no improvement; 3) replaced the SAAB light control relay (orange box), and no luck either. I am thinking that there could possibly be a short in the wiring or something of that sort, but at the moment, I am lost. Does anyone have any advice or had a similar expereince? Thanks!
Did you check the head lamp connector to see if +12 VDC was present? Or did you check the light bulb to see if there is continuety for the low beam filament? What kind of work was done? Was it an accident?... Ron
1 - 2 of 2 Posts
