I have been told I need a new one. It rattles around 35 mph, but it does seem to be muffling the sound of the engine.
Could something be loose and a simple tightning will fix it?
2006 Saab 9-5 2.3T, Stage lll ecu, 3" downpipe, 2.5" BSR cat back, 60th Ann wheels.
The rattling may just be a loose heat shield. If it is the muffler itself one solution is to have it replaced with a piece of straight pipe. Like I have done with my car. Cost about $120. If you look at the picture closely you can see my heat shield was loose as well. To fix that install a large washer under the retaining nut.
Also here is a clip of how my car sounds with the middle muffler removed.
Seasons Greetings!
http://www.youtube.com/watch?v=ZGHytKodfpI
Yep.
Mine had the same thing with the heat shield.... An oversized washer fixed it though.
