1 - 7 of 7 Posts
Hello,
I have a 1999 Sabb 93 and the turn signals stop working, I have the new turn signal relay but cannot find the location to replace to defective relay, I looked under the driver side panel beneath the steering column but can’t see it. Your help will be greatly appreciated.
Many thanks
Hi and welcome.
There is NO turn signal relay. TWICE controls them.
Check fuses 2,17 and 22 in dash fuse box.
Hi and welcome.
Thanks for the reply and will check the fuses noted and will post findings. Also, do you know where the TWICE is unit is located in the event replacement is required?
Thanks again
You need TECH2 if you want to change TWICE.
Fuses first, and then I would check the stalk itself. Might just need the contacts cleaned.
Might just want to verify that you don't have a short that blew all your bulbs.
1 - 7 of 7 Posts
