Hello All!
I almost have my 9-3 clutch back together after working on the clutch replacement with a shady mobile mechanic and after driving it around a bit my clutch pedal went to the floor. After checking it out I've realized the idiot mobile mechanic did not replace the bleeder block retaining ring or pin that connects it to the slave cylinder line. After taking a look around the shop I think I've found the ring that's supposed to hold it into place but its having a hard time engaging with the male end of the slave line. The ring seems to fit around the block and into the two slots but every time I think its on, I bleed the system and press on the pedal and it pops right back off. When I press it down onto the connection it pops into place nicely and is hard to pull back off so I think its in the right spot but if there are any suggestions on how to get it to fit or maybe pic/link to a website showing the ring to make sure I have the correct one, that would be helpful. My thought was if it won't go back into place, I could always use my aircraft safety wire and tool and create a tight connection between the two pieces holding it down into place. Any help or suggestions is appreciated. Thanks!
