After Changing the Head Gasket on 2.3L Turbo 9-5 due to coolant being in two of the cylinders the engine will not start.
The head was professionally machined and checked with new valve stem seals etc and a full VRS set used, I have spark through the new Ignition Cassette and plugs, fuel pressure is good, I believe the timing was correctly set as all off the marks lined up, the engine cranks over, there is no rattle from the chain and i can hear the odd fire but it will not start.
If anyone has any ideas please help me out, much appreciated.
I can hear the FP and my scanner is showing it to be on, the pressure seams to be quite good at the rail. I already took off the sump cleaned it right out including the pick up and have fresh oil in it, I will check the CPS next
