Good Evening!
I'm semi new to saabs as you know. I'm not sure if my ACC is shot, or if I'm not using properly. It seems the temp sensor that is near the seat heater button is buzzing and making noise. I searched some threads here, and have seen a few names for this. what is the actually name? is it a fan control sensor, or is this the temp sensor fan??
So usually when i start the car, the system seems to default to "HI" and fans blasting, regardless if i turn it off or the settings i had it on when i turned the car off. When i turn the the temp all the way down, it says low, but air doesn't seem to get cold. How do i engage AC? or is it all auto? Also, temp seems to go up to 83, and after 83 it goes to HI. is this how it works? Also i saw somewhere about error codes for AC. Would this trigger a dash light as well or no?
