1 - 11 of 11 Posts
what u guy think on this race...
me in the 1997 900se turbo
mods:
Intake
MBC set to fuel cut (15lbs)
Resonator back exhaust 2.5 inch with no resonator
or
a 2003 9-3 2.0 T
with intake
and new muffler
who do you think will win this battle?
In a street race it's whoever can recklessly endanger the life of himself and others the most who will most likely win. On a closed racetrack/road you should win as you have more boost and he has a stock setup (intake will make more noise but 0hp)
Sure but the stock intake IS a good intake - it's not restrictive and thus even in theory making it flow better has no effect on anything except to make it louder.
I have to disagree simply because I find it difficult to believe the oem intake inlet pipe being such a small diameter will flow better than an aftermarket 3" pipe. Also, the stock intake to turbo "crinkle" tube will not have laminar flow compared to a smooth 3" pipe.
Gains may be minimal but I doubt they are "0"
A smaller intake pipe creates higher air velocity which actualy helps spoolup and low end power. Think about holding your finger over the end of a hosepipe - the flow is the same but the velocity is increased. Saab made it a certain size for a reason - they would have absolutley nothing to gain by creating a restrictive intake and are quite capable of designing an efficeint free flowing and quiet intake. If your theory holds true then surley a 5" or 10" intake is all we need to create more power?
mods:
Intake
or
a 2003 9-3 2.0 T
with intake
and new muffler
how about u set me up with him:cheesy:
i need more videos
I don't feel that's as important on a forced induction vehicle as it is on a naturally aspirated one. The turbo is creating a fair amount of suction and keeps the air traveling at high velocity particularly under boost.
There should be plenty of velocity with an internally smooth 3" pipe and much less restriction.
Someone would just have to dyno the two setups on the same vehicle and change nothing else.
It's much easier to drink a milkshake through a large diameter straw than a small narrow one.
If you are talking an 03 9-3ss the intake is probably thowing codes left and right. If its not in limp home mode, the car probably has a ppc or something else going on with it.
Discussion Starter · #11 ·
you can have him after im done with him tolga...
and no i saw his car and he set up the intake wierd...its just a cone...its not even a full intake...and he said he gets codes from time to time...but he has no tune or ppc or anything....
1 - 11 of 11 Posts
