561 - 580 of 582 Posts
Discussion Starter · #564 ·
Got the oil pressure sender installed, went to crank it up, nada. Starter solenoid appears to have crapped out. Time for a new starter I guess.
Discussion Starter · #566 ·
No it acted up after the 4th or 5th burn-in run. No juice getting to the motor but the coil works. My kinda luck, motor is great but solenoid crapped out. Solenoid costs more than a rebuilt starter.
Discussion Starter · #568 ·
I found a bosch part for $50 but need to verify fitment. Cheaper than a $180 starter. I will jumper the starter and test things. Video maybe on this issue..
Discussion Starter · #569 ·
A few back to back tries and the contacts freed up. Starter motor is fine, gonna need a solenoid eventually. Oil pressure and coolant gauges are working. Time to swap out the dash trim and button it back up now that the SCC is fixed.
Maybe it's just sticky from sitting for a while. My XR sat for a year a while back and when I put it back on the road the starter was iffy. I bought a new one, but by the time it showed up the one on the car loosened up. That was four years ago. ;)
Discussion Starter · #571 ·
Nice color, no more cracks all over the dash face. A couple cluster bulbs to replace and I think the dash can be marked complete. Sound system is freaking LOUD. I love it at 11 but my ear drums hurt 3/4 up on the dial. Need to finish the back deck refresh and sub install next.
Vehicle Car Motor vehicle Steering part Steering wheel
Discussion Starter · #572 ·
Hood Automotive tire Bumper Rectangle Automotive exterior
Heavy skin install. Should be ready for the panel soon. Back seats may get skinned and covers sent to L-seat for new pattern. Not sure yet. May do that later. They work and have been restitched to fix splits. Just hard leather and ugly fading. I am going to have to make a trunk battery kit for this audio setup, though.
Discussion Starter · #573 ·
So it seems as though there may be a wiring or ground issue. When I turn on my dash lights and turn on the ACC the dash lights fuse blows. Not sure why since the blower is on its own circuit. I have a 30A fuse in for tracing and the wire is getting super hot at the fuse.
Definitely sounds like a bad ground for the ACC or blower... but weird that it would be trying to go through lighting. Maybe some unexpected internal wiring on the ACC itself?
Discussion Starter · #575 ·
G8 looked like a frosted flake. I soaked it with some coil cleaner and it is happy now. Tried swapping in a boost module from a 96 CSE and it got really confused. So did the tach. Was hoping my cluster collection was a quick swap. Nope, some parts work on my 94 some do not. Ah well I have the AEM gauge.
Hood Automotive tire Motor vehicle Automotive lighting Automotive design
Discussion Starter · #579 ·
Was a short in the tail lamp plate. I reseated the bulbs and put ATC breakers in the two fuse slots. No issues now. :rolleyes:
Car Automotive parking light Wheel Tire Automotive side marker light
NOS corner and headlight assembly.
