Not much going on right now. ABS pump is back together. Found a steal on ebay for a used system so grabbed it. Will mix/match between the two since the one port has damaged threads. Pulled the steering rack out and it's leaking around the rod seals. Not sure if I want to rebuild with new inner rods or just get a new/used one. It's heavily corroded outside, even the outer rod threads are gone. New rear engine mount installed, front subframe cleaned up, radiator removed and cleaned inside and out. Brake booster is coming off next for spot rust treating. Video soon on steering rack removal.
