321 - 327 of 327 Posts
Discussion Starter #321
I dunno which is worse, rotted burlap dust or grinder dust. This base was clogged with burlap chunks and thick burlap dust monsters.
The bun warmer is b0rked. :cautious:
276623
Discussion Starter #322
A burnt wire in a foam crease was the culprit for the heater not working. Soldered and works fine now. Soaking the leather cover for the seat bottom now. Hoping to get the seat working and bottom reinstalled this weekend. Padding and carpet has been re-installed. It's going to need dying to a slightly darker color due to the rust stains on the driver's side.
Discussion Starter #323
Seat foam looks good. Need some repair on the top coat though. The grey dye is worn off the bolster from getting in and out of the car.
276650
276651
Discussion Starter #324
Well that is exactly what I thought and it is not what I wanted to find. Sacrificial gearing. Why did they not use shear pins!?? Ugh...
276682
