281 - 290 of 290 Posts
Discussion Starter #281
Driver's rear door is being swapped. Video on that soon. Since I cut the door harness I have to pull the other door harness through and then test everything. The door handle is broken and the latch may need to be swapped as well. The panel is tan instead of grey so it will be up for sale shortly. In really good condition.
Discussion Starter #282
Everything works but I think the bottom seal is different. This came off a CSE. There is a lot of binding from the bottom sweep and the door will not shut fully.
274964
274965
Discussion Starter #283
NOTE: the trim pins on the CS doors are not at the same level as the CD doors(higher). I am going to have to use emblem tape to reinstall the CD trim on the replacement door.
Discussion Starter #286 (Edited)
ACC is working now, have a few connectors to redo. Did I mention how much I dislike those Volvo bullet connectors? Time to finish the floor pan repairs and get the dash back together.
Discussion Starter #288
Looks like I am going to have to pull the heater box back out and install the blower and heater box together from the inside. I can not get it to line up and rotate into the bottom. My cut up arms have had enough. I'm ready for the 60F temps at this point for the final welding work. I'll be taking my EPA 608 exam next week, already have my 609 for automotive. With that mini-split I'll need to buy R-410A to top off the unit.
Discussion Starter #290
And, of course, the duct extension for the RH defroster duct is no where to be found. So much for getting the dash frame back on tonight.
