1 - 2 of 2 Posts
Yesterday I went to lock my 94 and when I turned the key all the way to the right, it is supposed to lock all 4 doors but did not. I checked to see if there was a fuse but did not see one in the panel. Anyone have an idea of what went wrong? Is there something inside the door itself (drivers side) that may have broken or disconnected to cause this. As usual any help is greatly appreciated.
The drivers door lock key cylinder locks and unlocks the right front, right rear, left rear, and Fuel hatch via the power door lock circuit via a mirco switch located beside the drivers door lock key cylinder inside the door itself when the drivers door key cylinder is used to unlock and lock the car. The drivers door key lock cylinder also mechanically unlocks and locks only the drivers door normally and in the case of a no power sititutation (dead battery).
You might have to check the microswitch inside the door to ensure it hasn't become misaligned againest the key cylinder in the drivers door.
1 - 2 of 2 Posts
