Probably unlikely. Get a magnifier (or a pair of off-the-shelf reading glasses (I got a set with +4 magnification)) and inspect the board closely. You'll likely spot a dry joint or two. You can probably ignore the joints that are lacquered over and just solder those that are exposed. After doing this, reconnect the board (still out of its case), being careful to connect it the right way around!! Now try the lock and see do you get any reaction. If you do, things are good, if not, you now need to start diagnosing the wiring. Looking in the driver's door, you will either have a 5-wire motor connected to the lock or just a 3-wire switch. In each case, the 3-wire bit has a common wire and one lock and one unlock wire. Shorting the common to one or other of these wires should trigger the controller. Identify these wires at the door end, at the connector block in the wing just in front of the door hinge and at the controller. Short the appropriate locking two at the controller and see does it work. Try the unlocking pair. If it works there, you have to diagnose the wiring. Try shorting the same pairs at the door connector and then at the switch connector. Report back...
